gpuElegant results not matching elegant
joshec
Post by joshec » 06 May 2022, 08:02
After some experimentation, we're finding that the output of gpu-elegant for certain configurations seems to be failing. In particular, the particles don't seem to make it through the initial beamline elements, with subtleties as to what is going wrong. We're not quite sure where it is failing yet, but have some examples using the csbend component where this fails. TL;DR, gpu-elegant is losing particles.
I've rebuilt the newest version of elegant on our computing environment, gpu-jupyter (2021.4) and it shows the same behavior as the default install that we use (2021.1).
There's also a local build issue with elegant and CUDA 11 w/ GCC 11 that is known on other projects, likely due to a cstd versioning issue. I'm debugging that myself to build gpu-elegant locally on another system for testing as to if it is the version in our container that has issues or the code itself: c++17 vs c++14. I still need to build with c++17 instead as this requires changing some flags.
All commands were run as $ <binary> tracking.ele > <logfile>.log 2>&1
2021.1 non-GPU elegant (ele.log):
tracking 4000 particles
3 May 22 16:42:38: This step establishes energy profile vs s (fiducial beam).
3 May 22 16:42:38: Rf phases/references reset.
4000 particles present after pass 0
Adding OCT_K after (null)
4000 particles present after pass 4
4000 particles transmitted, total effort of 16000 particle-turns
33776880 multipole kicks done
2021.1 gpu-elegant (gpu-standard-ele.log):
3 May 22 16:41:48: This step establishes energy profile vs s (fiducial beam).
3 May 22 16:41:48: Rf phases/references reset.
0 particles transmitted, total effort of 0 particle-turns
18720 multipole kicks done
2021.4 gpu-elegant:
3 May 22 16:40:46: This step establishes energy profile vs s (fiducial beam).
3 May 22 16:40:46: Rf phases/references reset.
Post-tracking output completed.
Tracking step completed   ET:     00:00:01 CP:    1.43 BIO:0 DIO:0 PF:0 MEM:4838467
And an additional fun compilation message:
/home/vagrant/jupyter/oag/apps/src/epics/extensions/include/mdb.h:599: warning: "PI" redefined
  599 | #define PI 3.141592653589793
In file included from gpu_lsc.cu:1:
/home/vagrant/jupyter/oag/apps/src/epics/extensions/include/constants.h:35: note: this is the location of the previous definition
   35 | #define PI   3.141592653589793238462643
gpu-ele.log
(17.49 KiB) Downloaded 1072 times
ele.log
(49.5 KiB) Downloaded 1002 times
csben.tgz
(4.39 KiB) Downloaded 1004 times
Re: gpuElegant results not matching elegant
Post by soliday » 06 May 2022, 09:28
I build gpu-elegant with CUDA 10 due to an issue with the output when built with CUDA 11. I looked into this a while ago but failed to identify the issue and haven't had time to look at it again. There are other issues with gpu-elegant as you have seen, and it should only be used when you can verify that the output roughly matches the standard elegant output for the types of systems that you are simulating. I will run through the files you sent and see if I can identify the divergence.
