nonlinear-map from trackin
li.chao
Post by li.chao » 15 Mar 2022, 14:20
I am trying to get the non-linear one turn from from tracking. The script I am following is from elegant examples "ILMatrixFromTracking/"
The attached files are what I am using right now. In current stage, only two steps are included.
step 1, with the Basic.ele, the required chromaticity (5,5) is set, after running Basic.ele, the updated lattice parameter in saved in Basic.param, which is supposed to give chromaticity value (5,5)
setp 2, in closedOrbit.ele file, the Basic.param obtained from the step 1 is imported in, then it is used to get the closed orbit as a function of momentum derivation \delta. For each momentum, the main lattice information is printed out to the closedOrbit.twi file.
Here is my question: in the closedOrbit.twi file, I found the chromaticity in the first page are the values as I set (5,5), whereas in other pages, the chromaticity are (6,6)-- not the value I want to study
Is anything wrong in my script, or what should be improved to make the chromaticity correct in all pages in closedOrbit.twi.
yours Chao
P4_H6BA_v3_0.lte
(145.19 KiB) Downloaded 504 times
closedOrbit.ele
(832 Bytes) Downloaded 542 times
Basic.ele
(1.44 KiB) Downloaded 503 times
li.chao
Re: nonlinear-map from trackin
Post by li.chao » 16 Mar 2022, 11:12
It is all right. In stead of import *.paramer, file, the problem can be fixed with save_lattice command.
cheers Chao
li.chao
Post by li.chao » 10 May 2022, 08:15
I am trying to rebuild the nonlinear one turn-map from tracking. The attached is the script I am using.
Could please someone help me to confirm if I did it correct or not?
yours Chao
ilmatrixFromTracking.7z
(12.34 KiB) Downloaded 531 times
Post by michael_borland » 23 May 2022, 12:53
Chao,
I can't unpack your .7z file. Can you upload a .zip, .xz, or .gzip file instead?
