I calculated momentum aperture, ibs emittances with ibsEmittance and Touschek lifetime with touschekLifetime.
Then I plotted momentum aperture and square root of tmP and tmN, which look different from momentum aperture on attached figure. The difference is clearly visible while comparing the mmap and tlife files. The number of elements is identical.
Why is the difference? It looks like there is a some type of smoothing.
The second question is an attempt to understand the loss rate plot. The peak at s=588 m has minimum of H and minimum of dispersion comparing with immediate surrounding. What is the reason for the peak?
The beam energy is 1.5 GeV. I am using "elegant 2021.4.0 Nov 18 2021".
I attached the sorted mmap, tlife, and twi files.
Thank you,
Anton
Discrepancy between momentum aperture and Touschek
A.V.Bogomyagkov
- 2021.12.21-08.21.09_1.0crab-1.5GeV-8cav.zip
- (523.13 KiB) Downloaded 3409 times
Re: Discrepancy between momentum aperture and Touschek
Anton,
I can't reproduce your results. For this energy, sqrt(tmP) and -sqrt(tmN) are deltaPositive and deltaNegative. If I plot those, the agreement is essentially perfect. The FN and FP columns are misleading, since they are not integrated vs s. If you do that, the spike doesn't look so significant. For this plot, I normalized FN and FP to the circumference, then integrated vs s, so the units are 1/s.
A.V.Bogomyagkov
Thank you, Michael,
It is puzzling. I read sdds files into python pandas and plot them. The difference is obvious.
I also converted sdds files into ascii (both files are in the new attachment)
and compare mmap and tlife for element and the difference is visible
L2.MQ23 (s = 8.198064599999999e+01)
in mmap: deltaPositive = 5.000000000000000e-03
in tlife: tmP =5.424767157239484e-05 and the square root is sqrt(5.424767157239484e-05) = 0.0073653018656668
R1.MQ20 (s = 4.444997969999995e+02)
in mmap: deltaPositive = 1.4e-2
in tlife: tmP = 1.575137583744795e-04 and the square root is sqrt(1.575137583744795e-04) = 0.01255044853280071
For this energy
beta=math.sqrt(1 - ((me_mks * c_mks * c_mks) / (e_mks * 1.5e9))**2 ) = 0.9999999419733219
and doesn't change much.
Even if I use sdds tools to create new columns sqrt_tmP and sqrt_tmN I still get the same results
I use SDDS_ToolKit-x64.msi version 5.1
Integration of FP and FN is a good comment. I will implement this.
Anton
sddsconvert -ascii results/ct_ring.tlife results/ct_ting.tlife.ascii
sddsconvert -ascii results/ct_ring.mmap.sorted results/ct_ring.mmap.sorted.ascii
For this energy
sddsprocess results/ct_ring.tlife -pipe=out \
-define=col,sqrt_tmP,"tmP sqrt" \
-define=col,sqrt_tmN,"tmN sqrt" \
| sddsconvert -pipe=in results/ct_ring.tlife_new
!sddsconvert -ascii results/ct_ring.tlife_new results/ct_ting.tlife_new.ascii
Anton
- (1.1 MiB) Downloaded 3565 times
Skamarokha
I have reproduced the problem mentioned above by Anton with different lattice. Maybe the problem is in touschekLifetime program?
Here is version of the program I am using on Windows:
Program by A. Xiao, M. Borland. (This is version 8, March 2017, M. Borland) Last bumped by Skamarokha on 03 Jun 2022, 03:28.
Respectfully,
Mikhail A. Skamarokha.
