Just wondering if it is possible to plot a matrix element (e.g. R12) vs s for a given beamline?
chris
Matrix elements
Re: Matrix elements
Chris,
You can do this by using the matrix_output command to get the matrix into an SDDS file, e.g.,
&matrix_output
SDDS_output = <filename>,
SDDS_output_order = 1
This will output the first-order matrix elements vs s for the beamline named in run_setup.
&matrix_output
Re: Matrix elements
Fantastic! For some reason I had been using printout="%s.mpr" rather than SDDS_output. Thanks.
