WATCH element Pelevant vs Elegant behavior
nadolski
Post by nadolski » 08 Dec 2021, 09:09
Dear All,
I am running a very simple example with the track command.
The output is different between elegant and Pelegant.
elegant mytest.ele produce mytest.w1 as expected
mpirun -n 2 Pelegant mytest.ele does not produce any mytest.w1 file.
Could you please explain why ?
Is this a bug ?
Laurent.
mytest.tgz
(2.28 KiB) Downloaded 628 times
Re: WATCH element Pelevant vs Elegant behavior
Post by michael_borland » 08 Dec 2021, 13:08
Laurent,
The problem is that you are asking to do parallel tracking with only 1 simulation particle. It is a bug, I think, but perhaps an understandable one.
If you increase the number of particles to at least equal the number of cores, it will be fine. Typically to get a benefit from parallel tracking you should use "many" particles per core. Otherwise, interprocess communication may negate any benefit from parallelism.
How many you need to get a benefit will depend on the particular simulation.
nadolski
Post by nadolski » 08 Dec 2021, 16:11
It was working nicely in the past.
Thanks Michael for the quick answer.
Now I now how to modify my code.
Laurent.
