Dear All,
I would like to use frequency_map to compute the horizontal amplitude versus the energy offset.
Per default the particule not launched with respect to the chromatic orbit as explained in the doc.
&frequency_map
output = %s.fmadp,
xmin = 10e-6,
xmin = 10e-6,
xmax = 0.02,
delta_min = -0.06,
delta_max = 0.06,
nx = 101,
ny = 1,
ndelta = 201,
include_changes = 1 ! compute diffusion
Is there an option to center the particle around the dispersive closed orbit ?
Laurent.
frequency_map around closed orbit
Re: frequency_map around closed orbit
Laurent,
If I understand correctly, you want to perform FMA but with the particles x positions offset by the momentum-dependent closed orbit. There's no way to do that with the frequency_map command, but it can be done with scripts. The tracking is still done with Pelegant, so the performance is comparable to using the frequency_map command.
See the attached files for an example.
- fmaExample.zip
- (5.04 KiB) Downloaded 1832 times
nadolski
Thanks, this is really helping.
Being guided helps a lot to learn ELEGANT and SDDS routines.
