I'm using elegant 2021.1.0, I'm trying to use I/Q feedback of RFMODE to simulate an active RF cavity.
As I understand, if PRELOAD is set, or initial beam loading voltage/phase is set up, i.e., the tracking starts with a specified initial beam loading \vec{Vb}, then the generator voltage \vec{Vg} will be set up so that \vec{Vg}+\vec{Vb} =\vec{Vc0}, \vec{Vc0} is the desired total RF voltage. However, in the later tracking, the RF feedback would aim at a total voltage \vec{Vc} = \vec{Vc0} + \vec{Vb}, rather than \vec{Vc0}.
In the source file rfmode.cc Line 489&490, VISetpoint & VQSetpoint include the following contribution: rfmode->V0 * cos(rfmode->last_phase0) or rfmode->V0 * sin(rfmode->last_phase0), this seems to double-count the beam loading voltage.
It would be highly appreciated if you could check this issue.Thanks!
Zhe
RFMODE I/Q feedback w/ PRELOAD or initial beam loading voltage/phase
Re: RFMODE I/Q feedback w/ PRELOAD or initial beam loading voltage/phase
Zhe,
In lines 492 and 493, the generator current is recomputed using VISetpoint-VI and VQSetpoint-VQ, VI and VQ also contain contributions from the beam loading (see lines 410-414), so these are basically subtracted off. Does that address your concern?
In the manual for RFMODE, V_SETPOINT & PHASE_SETPOINT are setpoints for total cavity voltage and phase. The amplitude/phase feedback loop is consistent with this statement.
For I/Q feedback loop, in line 489/490, rfmode->voltageSetpoint & rfmode->phaseSetpoint are the total cavity voltage and phase, while VISetpoint & VQsetpoint thus calculated, are the generator voltage and phase. However, in line 492 & 493, VI & VQ are the sampled total cavity voltage and phase, therefore VISetpoint-VI & VOSetpoint-VQ have a beam loading voltage component, in addition to the desired difference between the setpoint of total voltage and the sampled total voltage.
488 phaseg = PI/180*rfmode->phaseSetpoint - 3*PI/2;
489 VISetpoint = (rfmode->voltageSetpoint+rfmode->setpointAdjustment)*cos(phaseg) + rfmode->V0*cos(rfmode->last_phase0);
490 VQSetpoint = (rfmode->voltageSetpoint+rfmode->setpointAdjustment)*sin(phaseg) + rfmode->V0*sin(rfmode->last_phase0);
492 rfmode->Iiq->a[0][0] = rfmode->Ig0->a[0][0] + (dII=applyIIRFilter(rfmode->IFilter, rfmode->nIFilters, rfmode->lambdaA*(VISetpoint-VI)));
493 rfmode->Iiq->a[1][0] = rfmode->Ig0->a[1][0] + (dIQ=applyIIRFilter(rfmode->QFilter, rfmode->nQFilters, rfmode->lambdaA*(VQSetpoint-VQ)));
In the attached example, I launched three simulations, Case 1 (folder name : no_feedback) is for the case w/o RF feedback by tweaking the filter.sdds file, the cavity is preloaded with a bunch charge of 15nC, and the evolution of Vc near 8MV in the tracking is expected; Case 2 (folder name : proportional_feedback) is for the case w/ a proportional feedback, in the tracking, Vc is seen rising to 8.4MV( Vc0 + Vb ) instantly and then being stabilized; Case 32 (folder name : proportional_feedback_modified) is doing the simulation as Case 2, but the source file is modified in the following way, the evolution of Vc is now close to expectation.
489 VISetpoint = (rfmode->voltageSetpoint+rfmode->setpointAdjustment)*cos(phaseg) ;
490 VQSetpoint = (rfmode->voltageSetpoint+rfmode->setpointAdjustment)*sin(phaseg) ;
Thanks and best regards,
Zhe
Zhe
- elegant_example_IQ_preload.tar.gz
- (5.3 MiB) Downloaded 1214 times
Zhe,
Thanks for the detailed explanation and examples. I agree with your correction and it will appear in the next version.
By the way, I liked your trick of using echo and csv2sdds to make an SDDS file. You can also use the program sddsmakedataset.
Thanks again.
Thanks again.
Thanks for checking this out! I'll try using sddsmakedataset next time as you suggested.
Cheers,
Zhe
Cheers,
Zhe
