ZLONGIT reads in impedance file wrong
Teresia
Post by Teresia » 28 Apr 2021, 05:11
I have a problem with the <filename>=<x>+<y> format when using the ZLONGIT element. I have a SDDS file with three columns, Freq, RealZ and ImagZ corresponding to the frequency, real and imaginary part of an impedance. Even if I specify that that ZREAL and ZIMAG should use different columns it seems they read in the same. The only way I have managed to get it to read in different columns is by separating the real and imaginary part into two different SDDS files.
I discovered it since I could only get the wake and impedance simulations to agree for cases where the real and imaginary impedance is the same. Also, I only got the "error: impedance spectrum has non-zero imaginary DC term (ZLONGIT)" depending on the DC term of the real part, indicating that the real impedance is read in also for the imaginary part.
Am I doing something wrong or is this a bug?
I have attached some files where I get the problem and also the only way I have found to get around it.
Teresia
zlongit-files.zip
(6.85 MiB) Downloaded 808 times
Re: ZLONGIT reads in impedance file wrong
Post by michael_borland » 14 May 2021, 10:44
Teresia,
The problem is that the quotation marks need to be escaped in the insert_elements command. Instead of
&insert_elements
        name = impedance,
        element_def = "lon_rw_impedance: zlongit,zreal="impedance_elegant.sdds"="Freq"+"RealZ",zimag="impedance_elegant.sdds"="Freq"+"Im
agZ",interpolate=1,bunched_beam_mode=1"
you should use
&insert_elements
        name = impedance,
        element_def = "lon_rw_impedance: zlongit,zreal=\"impedance_elegant.sdds=Freq+RealZ\",zimag=\"impedance_elegant.sdds=Freq+ImagZ\"
The \" sequence allows putting a quotation mark inside a quoted string.
Teresia
Post by Teresia » 21 May 2021, 07:06
Ah! Thank you. I wasn't aware of this. I will try that.
Teresia
