I am trying to simulate the pulsed beam injection into the ring in the ELEGANT.
The revolution period is about 13 us. We want to inject a series of bunch trains-consisting of only two bunches spaced by 2us-in an interval of 10ms. In the input file, how can I generate this pulsed beam structure? It looks like once I set the bunch frequency to be 1/(2 us) and step number to be 2, there is no option left to generate the next bunch train after 10ms. Any suggestion would be welcome.
pulsed beam generation
Re: pulsed beam generation
Here's a script that can generate an arbitrary bunch pattern. You can use the generateBunch script first (it should be installed already if you have installed elegant).
The script accepts a pattern specification as described here
For example, to generate a 325MHz bunch train as follows
usage: generateBunchTrain -input <bunch> {-patternFile <filename> | -patternString <string>} -rfFrequency <Hz> -output <filename>
The input file should be generated by elegant's bunched_beam command or equivalent; it should contain only one bunch.
The pattern file has two columns: BucketNumber (integer) and RelativeIntensity (a value (0,1]).
The pattern string has the form: <n1>*<s1>*<i1> <n2>*<s2>*<i2> ... where <n1> is the number of
bunches, <s1> is the spacing in rf buckets, and <i1> is the relative intensity, etc.
E.g., 5*1*1.0 5*1*0.0 5*2*1.0 specifies two 5-bunch trains separated by 5 empty buckets;
the first train has single-bucket spacing, while the second has two-bucket spacing.
- 5 bunches separated by 1 bucket with intensity=1.0
- 10 empty buckets
- 3 empty buckets
- 10 bunches separated by 2 buckets with intensity=3.0
generateBunch -output bunch.sdds -number 10000 -xplane 60e-9,5.2,0.0,0.0,0.0 -yplane 16e-9,2.4,0,0,0 -zplane 6e3,10e-3,0.12e-2
generateBunchTrain -input bunch.sdds -output train1.sdds -patternString "5*1*1.0 10*1*0 5*1*1.0 3*1*0 10*2*3.0" -rfFrequency 352e6
- generateBunchTrain.zip
- (1.42 KiB) Downloaded 2061 times
Thanks for the reply.
I first tried to generate the bunch by using the command line you suggested:
But the error message showed up
'generateBunch' is not recognized as an internal or external command, operable program or batch file
I checked the elegant folder and found the generateBunch file in there. I copied and pasted the 'generateBunchTrain' file into the elegant folder and tried
but I had the same error message. So I am a little puzzled why I am having these error messages. This is my first time running the script file. Could you let me know what is going on?
Gunn Tae
Gunn Tae
Gunn Tae,
What operating system are you using?
I am using 64-bit Windows system.
Are you using cygwin, or a Window's shell?
Probably your search path is not set correctly.
I use Window shell (command prompt). As an experiment, I moved two 'generate..' files to my working folder and tried 'generate..' command. Things still did not work. How do I set the correct search path (probably the first couple of lines in two 'generate...' files)?
Gunn Tae
Gunn Tae
