gpu-elegant doesn't work for dynamic aperture tracking
Gyeongsu
Post by Gyeongsu » 14 Jan 2021, 03:12
I tried to use gpu-elegant. As far as I know, there is no special command or additional coding to use gpu-elegant. Just replacing the "elegant" to "gpu-elegant" is okay. To check it, I tested the gpu-elegant with the elegant examples(which is on the aps elegant web site). First PAR/twissCalculation was tested. I just replaced the command on the "parTwiss" script from
if ![file exists parTwiss.log] {
catch {exec elegant parTwiss.ele > parTwiss.log}
to
catch {exec gpu-elegant parTwiss.ele > parTwiss.log}
For the both cases, the same results were obtained.
After that, I tested PAR/dynamicAperture. Again I just replaced the command on the "track" script from
catch {exec elegant parTrack.ele -macro=deltaFile=deltaValues.sdds > parTrack.log}
to
In this case, elegant gave reasonable results. However, gpu-elegant gave an error message. It was
Fiducial particle lost. Don't know what to do.
Lastly, I checked PAR/tracking in the same way. Elegant gave reasonable results. gpu-elegant gave the different results that all particles were lost during the tracking.
Why the gpu-elegant doesn't work for the tracking and dynamicAperture? If there are anything I misunderstand or miss. Please let me know the right way of using gpu-elegant.
Gyeongsu
Re: gpu-elegant doesn't work for dynamic aperture tracking
Post by michael_borland » 22 Feb 2021, 22:33
Gyeongsu,
We are looking into the problem.
