parameter output of "linked" & "divided" elements
michael_abo-bakr
Post by michael_abo-bakr » 16 Nov 2020, 08:32
looking to the lattice element parameters, saved when requested in run_setup, the value of a linked element seems to be wrong if "element_divisions" is larger than 1.
I have to admit using, a somewhat outdated version (2019.1.1) but I couldn't find any hints, that this has been a topic already ...
I attach two condensed files.
Thank you & take care, Michael
Test.ele
(1006 Bytes) Downloaded 862 times
lat_saved.lte
(554 Bytes) Downloaded 918 times
Re: parameter output of "linked" & "divided" elements
Post by michael_borland » 25 Nov 2020, 16:32
When dealing with divided elements, it is important to remember that all the divisible properties will appear in their subdivided form in any expressions. Hence, you need to modify the equation to reflect the division. See attached.
Test.ele
(973 Bytes) Downloaded 871 times
michael_abo-bakr
Post by michael_abo-bakr » 26 Nov 2020, 11:21
that works fine!
I was using this within an optimization - so I was additionally confused since also the limit values of the optimization variables are affected!
I think for "additive" element parameters like length or angle the optimization_variable definition (of every element?) must include the devision too:
&rpn_expression  expression = "10 sto div"  &end
&run_setup
    element_divisions = "(div)",
&optimization_variable
	name = BB, item=L, upper_limit="<UpperLimit_orig> div /", lower_limit="<LowerLimit_orig> div /"
Thanks a lot,
Michael
