I want to use the coupled_twiss_output command to calculate the beam sizes, however, it does not output the beam size parameters to the ".ctwi" file(see the attached files). How can I get these parameters?
Thanks!
duanz
coupled_twiss_output command doesn't calculate beam sizes
- parTwiss.ele
- (578 Bytes) Downloaded 1668 times
Re: coupled_twiss_output command doesn't calculate beam sizes
Sorry I didn't see this one sooner.
The best way to compute the beam sizes with coupling is using the moments_output command.
I've attached an example.
For example, to see the vertical beamsize due to quadrupole tilt errors
% elegant parMoments.ele
% sddsplot -column=s,s3 parMoments.mom -split=page
- parMoments.ele
- (541 Bytes) Downloaded 1579 times
- par.lte
- (2.48 KiB) Downloaded 1532 times
