Aperture for EHKICKER, EHKICK, EVKICK
Youssef
Post by Youssef » 16 Sep 2020, 01:38
Hi all,
i have a problem, when i change the values for EHKICKER (HKICK or VKICK) and want to output the twiss, the xApertures and yApertures values are changing...I wonder why? I tried EHKICK and EVKICK, the results are the same (changing the apertures values).
Could you please help me get to the bottom of this problem?
Regards,
Youssef
test_lattice.lte
(232 Bytes) Downloaded 690 times
test_ele.ele
(398 Bytes) Downloaded 679 times
test.twi
(10.38 KiB) Downloaded 665 times
duanz
Re: Aperture for EHKICKER, EHKICK, EVKICK
Post by duanz » 20 Sep 2020, 05:11
Hi Youssef,
I think the reason is that the introduction of EHKICKER changes the closed orbit, and when ELEGANT computes xApertures and yApertures it takes into account the local closed orbit deviation, i.e., when a particle arrives at a specific point in the ring, if the local closed orbit is nonzero, then the particle sees a reduced physical aperture in either the +x or the -x direction.
I hope this helps.
Cheers,
Zhe
Youssef
Post by Youssef » 29 Sep 2020, 05:36
Hi Zhe,
thank you for your reply. i.e. to have the right apertures, I have to add the amount of the aperture reduction to the aperture's values?
Regards,
Youssef
