Accuracy of exact drift implementation
nkuklev
Post by nkuklev » 04 Sep 2020, 15:10
I was playing around with adding new elements, and noticed that drift tracking results from MAD-X and elegant are different. I initially thought both codes had exact drifts.
However, in csbend.c:
void exactDrift(double **part, long np, double length)
  long i;
  double *coord;
  for (i=0; i<np; i++) {
    coord = part[i];
    coord[0] += coord[1]*length;
    coord[2] += coord[3]*length;
    coord[4] += length*sqrt(1+sqr(coord[1])+sqr(coord[3]));
This seems to be a rough approximation of the exact solution (2.35, 4.2 of https://cds.cern.ch/record/1642385/file ... 13-248.pdf).
  • Am I correct in interpreting this approximation as beta~1 + expansion in x'/y', suitable for larger rings?
  • Could 'true exact' mode be added? It would be useful for small rings, and benchmarking with other codes. I can give it a shot, but elegant coordinates still scare me hehe.
  • Regardless, can documentation be clarified to indicate these approximations?
Re: Accuracy of exact drift implementation
Post by michael_borland » 07 Sep 2020, 14:42
I'm pretty sure this is indeed an exact result. The definition of x' is x' = px/pz = vx/vz = dx/dz. Hence, if the drift space has length L, the change in x is just x'*L.
Perhaps you are thining that xp and yp are momenta, which they aren't.
