I was trying to modify the RFCA elements in one .ele script and dump the modified lattice with the save_lattice command. However, in the new lattice file generated, the PHASE_REFERENCEs of RFCA elements are some very large integers like 9223372036854775807. When I use this lattice for later tracking, I got an error "error: please use a small integer for the phase_reference number".
I then tried to set PHASE_REFERENCE to 0 (the default value) in the .ele script, but found this PHASE_REFERENCE = 0 didn't go into the parameter file, and thus didn't override its value of a very large integer in the lattice file generated with save_lattice. If I set PHASE_REFERENCE to some positive value, I could see its value appear in the parameter file, and also in the lattice file generated with save_lattice. But this might not be the preferred setting, since I don't assume the RF phase would be linked with some other time-dependent elements.
Thanks and best regards,
Zhe
One issue with PHASE_REFERENCE of the RFCA element
Re: One issue with PHASE_REFERENCE of the RFCA element
Zhe,
I'm very surprised that the saved lattice would have those strange values for the PHASE_REFERENCE parameter. Can you send me an example that illustrates this?
Thanks--Michael
Thanks--Michael
I use PAR ring as an illustration, see attached files. I used both a MAC and a linux server, the results are the same.
Zhe
Zhe
- test.tar.gz
- (21.63 KiB) Downloaded 1368 times
Zhe,
The bug seems to be in save_lattice when output_seq=1. If you can set this to 0 (in most cases it is ok), that will solve it for now.
Zhe,
I've fixed this bug. The fix will appear in the next release.
Thanks again.
Thanks again.
Thanks! This did solve the strange large value of PHASE_REFERENCE when dumping the lattice.
Zhe
Zhe
