tuneshift with amplitude
marlibgin
Post by marlibgin » 26 Jun 2020, 09:21
I have a general and trivial question
I am trying to activate the calculation of the higher oder thune shifts with amplitude (dnux/daX2, dnuy/dAy2 etc)
using a combination of tune_shift_with_amplitude and twiss_output commands.
However while the linear terms are calculated, there all the higher order elements remain zero
dnux/Ax2 =0.0000 dnux/dAxdAy=0.0000 ...
this is the fragment of my *.ele text. I 'd like to find the flag that activates this calculation:
&tune_shift_with_amplitude
turns = 0,
x0 = 1e-06,
y0 = 1e-06,
x1 = 0.03,
y1 = 0.03,
grid_size = 6
&twiss_output
filename = %s.twi,
radiation_integrals = 1,
matched = 1,
output_at_each_step = 1,
concat_order = 3
higher_order_chromaticity = 1
higher_order_chromaticity_range = 0.0002
chromatic_tune_spread_half_range = 0
compute_driving_terms = 1
leading_order_driving_terms_only = 1
beta_x = 1
beta_y = 1
alpha_x = 0
alpha_y = 0
eta_x = 0
etap_x = 0
Re: tuneshift with amplitude
Post by michael_borland » 30 Jun 2020, 12:49
I've attached a example that may help.
Please note that higher-order coefficients are not always reliable due to the difficulty of identifying and determining tunes when there is motion is both planes at larger amplitudes.
tswa.zip
(1.37 KiB) Downloaded 581 times
