How can I make a beam with higher order dispersion etax2, etax3 included?
Farzad
Beam with higher order dispersion
Re: Beam with higher order dispersion
Farzad,
We don't have a tool for that, but you can add it by hand. E.g.,
Of course, you'll also want to include the corresponding changes to the slopes, if any.
sddsprocess beam0.sdds beam1.sdds \
"-define=parameter,etax2,1,units=m" "-define=parameter,etax3,0.1,units=m" \
"-define=column,delta,p pCentral / 1 -" \
"-redefine=column,x,x etax2 delta sqr * + etax3 delta 3 pow * +,units=m"
