Inconsistence in particleID generated with bunched_beam using Elegant and Pelegant
duanz
Post by duanz » 02 Feb 2020, 23:17
As shown in the attached example, I attempted to use the first_is_fiducial mode in run_control and bunched_beam, to generate a first beam with a single particle for fiducialization and then track the second beam with the desired beam distribution. If I execute Elegant, the particleIDs of the second beam starts from 2. In contrast, if I execute Pelegant, the particleIDs of the second beam starts from 1. This could lead to some inconsistence if one wants to alter the DT of MALIGN among a range of particleIDs, say, only for the second beam.
Zhe
pid_inconsistence.tar.gz
(1.26 KiB) Downloaded 3509 times
Re: Inconsistence in particleID generated with bunched_beam using Elegant and Pelegant
Post by michael_borland » 07 Feb 2020, 13:21
Zhe,
Thanks for reporting the bug. The fix will appear in the next release.
If you build from source, you can use the attached file.
bunched_beam.c
(49.16 KiB) Downloaded 3373 times
