Tilting quadrupoles
Neeraj
Tilting quadrupoles
Post by Neeraj » 17 Jan 2020, 10:10
Hello Michael,
I was wondering if there is a way one can introduce tilts (pitch and yaw) about the axes perpendicular to the magnetic axis of KQUAD? It would have been much easier if it was possible to do it with element parameters in elegant for error studies.
(At the moment I am thinking of loading 'tilted field maps' from a magnet model.)
cheers,
Neeraj
Re: Tilting quadrupoles
Post by michael_borland » 20 Jan 2020, 16:24
Neeraj,
The only way to do this at present is using MALIGN elements before and after the KQUAD. E.g.,
mal1: malign
mal2: malign
Q1: KQUAD,L=0.20494743951919,K1=3.946439610164161,&
 N_KICKS=48,EDGE1_EFFECTS=1,EDGE2_EFFECTS=1,I0P=0.003824662127752904,&
 I1P=6.903339913689746e-05,I2P=2.972459683194837e-06,I3P=2.03620440157978e-07,&
 LAMBDA2P=1.451116689085801e-07,I0M=-0.003677869867790978,&
 I1M=1.815037845766118e-05,I2M=-2.368849318580891e-07,&
 I3M=8.218609250308457e-09,LAMBDA2M=3.037179653285794e-08
bl: line=(mal1,q1,mal2)
&alter_elements name=MAL1, item=DXP, value=1e-2 &end
&alter_elements name=MAL1, item=DX, value="(1e-2 0.20494743951919 * -2 /)" &end
&alter_elements name=MAL2, item=DXP, value=-1e-2 &end
&alter_elements name=MAL2, item=DX, value="(-1e-2 0.20494743951919 * -2 /)" &end
You'll see a sextupole-like term. See attached.
kquadYaw.zip
(1.86 KiB) Downloaded 568 times
