Can anybody help me change plot ranges in sddsplot?
I could change the "center" of the range by something like,
sddsplot -graph=line,vary -unsup=y -column=s,eta? -range=ycenter=0 -yscale=id=2 XXX.twi -legend,,,,,
However, once I use "-range=yminimum=-2,ymaximum=2", the plot range is automatically adjusted and my command is ignored...
Thanks in advance!
How to change ranges in sddsplot
Re: How to change ranges in sddsplot
If you just want to specify fixed scales, try the -scales option, e.g.,
sddsplot -column=s,betax -scales=0,0,0,30
would plot betax between 0 and 30, but autoscale on y.
Let me know if this isn't why you are trying to do.
Micheal,
Thank you for the quick reply and useful information.
Following your advice, I was able to change the scalings as I wanted.
Takahiro
Takahiro
