I have a simulation setting where the beam goes through the lattice 11 times by setting n_passes=11 (physically corresponding to the beam circulating the lattice 11 times). I also setup watch points. Now I want to have separate plots of phase space (t-p, etc) at watch point W1 in each turn. With the command I know, which is sddsplot W1.sdds -col=t,p -graph=dot, I only obtain the plot with all of 11 turns overlapped. Could you let me know how?
Thanks
Gunn
plotting phase space separately in each pass
Re: plotting phase space separately in each pass
Gunn,
Each pass of the beam is put into a separate "page" in the output file. By default, sddsplot treats all the pages as a single set of data.
Plot all the data together:
Split the data pages, but plot the data together with different color:
Split the data pages and show them on different plot pages:
It is sometimes more useful to use "dt" instead of "t" in these plots, since it doesn't increase with each pass. Also, you might want to plot the fractional energy deviation and keep fixed scales
sddsplot W1.sdds -col=t,p -split=page -graph=dot,vary -legend=param=Pass
sddsplot W1.sdds -col=t,p -split=page -separate=page -title=@Pass -graph=dot
sddsplot W1.sdds -col=dt,p -split=page -separate=page -samescales -title=@Pass -graph=dot -factor=yparam=pCentral,yinvert -offset=yparam=pCentral,yinvert -ylabel=delta
