I am trying to construct an ILMatrix using the output from frequency_map to get the tune and and amplitude-dependent tune shifts from tracking, but the output I get doesn't agree with what I expect or what I get by doing a FFT on the output from track.
To test I tried running frequency_map for one step using only a small amplitude in both x and y. I expected to get tunes close to what I get from track and a path length close to the circumference of the machine. This is the output:
x y nux nuy s
m m m/pass
1.000000e-12 1.000000e-12 1.896258e-01 2.776528e-01 5.611217e+02
However, running track gives me the s/pass 561.571 m (which agrees with the circumference) and the tunes 0.1916 and 0.2804.
Is frequency_map doing something different than track that might explain this? I thought the frequency map was just running tracking for particles with different initial amplitudes, but perhaps the code is doing something more complex than this?
Teresia
Output from frequency_map doesn't agree with tracking
Re: Output from frequency_map doesn't agree with tracking
Teresia,
The most common cause of this would be using too few kicks on the CSBEND and KQUAD elements. This can cause tune errors, but also path-length errors (due to CSBEND). Try increasing the N_KICKS parameters.
