Zhen,
Alas, we didn't think to provide that feature. Should be easy to get into the next version. If you build from source, I can provide a patch.
laser modulation in helical undulator
Re: laser modulation in helical undulator
Zhen,
Actually, you can do that. I missed it when I checked the manual. Just set the LASER_TILT parameter to whatever angle you want (default is zero).
Sorry I didn't notice your reply. I am confused about the LASER_TILT. I thought it meant to tilt the wave front of the laser pulse, which is similar with the work of Phys. Rev. ST Accel. Beams 17, 070701. Here I want to rotate the polarization direction of the laser to generate electric field components of the laser in the two directions. Is this different with the meaning of the LASER_TILT?
Thanks for your help.
Zhen
Zhen
Zhen,
Sorry for the late reply. LASER_TILT is rotation about the propagation axis, so it's what you want.
