modulate_elements
Re: modulate_elements
Here you go!
- ForMike.zip
- Hack version
- (5.04 KiB) Downloaded 556 times
Thanks!
I _may_ have found another bug in Modulate_elements. Attached is a demo which saws the possible bug. It is similar to the previous example except that now I turn on the RF system. When I turn on the RF, there are two things I see:
1) for modulate elements, I need to have negative times in my file which specifies the element values, othwerwise I get an error that the interpolation fails when it encounters a particle with negative times.
2) the phase space behaviour is _VERY_ different with the RF on. Some of this is expected, synchrotron oscillations etc, but the islands I get with no RF completely disappear. If I start the scan at settings which generate the islands, they appear, but if I try to move the islands with the scan, they do not move.
I believe this may be an error in the code, but I am not whole heartedly convinced, but it smells like a duck, and walks like a duck.
Ray
Ray
- ForMike.zip
- (4.62 KiB) Downloaded 519 times
Ray,
I'm a bit swamped right now. One suggestion is to try the MODRF element, which allow imposing various modulations in an rf cavity. Also, RAMPRF allows specifying time-dependent waveforms for phase and amplitude.
The modulation is not on the RF, it is still on the quadrupoles. I am just adding in the RF to the dynamics.
Ray
Ray
Ray,
Ok, I'll try to have a look in the next few days. One thing you might check is whether it is the same with QUAD and KQUAD elements. It should be very similar.
It is pratically unchanged.
Ray
Ray
Ray,
Try setting change_t=0 on the RFCA. Otherwise, you are reseting the average particle coordinates to <t>=0, which is going to mess up the calculation of the modulation amplitude.
BINGO, worked like a charm. Thanks for your help.
Ray
Ray
