Can elegant perform dynamic Aperture optimization ?
csun
Re: Can elegant perform dynamic Aperture optimization ?
Post by csun » 22 Apr 2010, 16:53
Hi Weiming Guo,
Thanks for your example. In the example, you are using dnux/dp and dnuy/dp to target the desired chromaticity. I am just curious why you don't use the linear chromaticity driving terms h11001 and h00111? I noticed that in the twiss parameter output file, the driving terms h11001 and h0011 are not close to zero even though the dnux/dp and dnuy/dp are already corrected to zero. My understanding is that those driving terms are related to the linear chromaticity by a pi factor, i.e. dnux/dp = h11001/pi. Here is the partial ouput of the twiss parameter file :
Step = 0 nux (1/(2$gp$r)) = 2.145948e+01 dnux/dp (1/(2$gp$r)) = 1.165833e-01
dnux/dp2 (1/(2$gp$r)) = -2.433317e+02 dnux/dp3 (1/(2$gp$r)) = -9.040604e+03 Ax (m) = 0.000000e+00
nuy (1/(2$gp$r)) = 8.196170e+00 dnuy/dp (1/(2$gp$r)) = -5.312905e-01 dnuy/dp2 (1/(2$gp$r)) = -2.594767e+02
dnuy/dp3 (1/(2$gp$r)) = 1.617910e+03 Ay (m) = 0.000000e+00 deltaHalfRange = 0.000000e+00
h11001 = 2.719532e+01 h00111 = 2.444541e+01 h20001 = 5.295725e-01
h00201 = 2.676596e+00 h10002 (1/m$a1/2$n) = 5.098531e-01 h21000 (1/m$a1/2$n) = 3.118103e+01
h30000 (1/m$a1/2$n) = 1.152045e+01 h10110 (1/m$a1/2$n) = 6.389664e+01 h10020 (1/m$a1/2$n) = 2.782511e+00
h10200 (1/m) = 9.747550e+00 h22000 (1/m) = 4.764831e+01 h11110 (1/m) = 2.478521e+02
h00220 (1/m) = 2.567794e+02 h31000 (1/m) = 1.122561e+01 h40000 (1/m) = 5.612807e+00
h20110 (1/m) = 8.477368e+01 h11200 (1/m) = 2.769764e+01 h20020 (1/m) = 1.117740e+01
Are those driving terms not precisely calculated in elegant? Thanks!
csun
wguo
Post by wguo » 22 Apr 2010, 20:39
Hi Sun,
I need your lattice file before I can tell if the results are correct.
Regards,
Weiming
csun
Post by csun » 22 Apr 2010, 21:00
Attached are the files I use to generate twiss parameters. Thanks!
csun
twiss.ele
(450 Bytes) Downloaded 1163 times
als.lte
(1.42 KiB) Downloaded 1190 times
wguo
Post by wguo » 23 Apr 2010, 09:54
Hi Sun,
I don't see any problem with the input files.
For linear chromaticity we use dnux/dp and dnuy/dp instead of h11001 and h00111 is because the h coefficients are calculated only at the quadrupole and sextupole locations (1/rho^2 is not counted either); therefore the result is not as precise as that obtained from twiss_command. The other quadrupole related terms have the similar approximation. If the magnets are long, one could set element_division to >1 to obtain better precision.
Regards,
Weiming
Contact:
Post by michael_borland » 23 Apr 2010, 09:58
I plan to release the genetic optimization software for dynamic aperture and local momentum aperture in the near future. I post something when it is available.
csun
Post by csun » 23 Apr 2010, 11:16
Thanks, Weiming and Michael. I am looking forward to the release of the genetic optimization.
CSun
Hwang, Ji-Gwang
Post by Hwang, Ji-Gwang » 09 May 2010, 07:27
Hello, Dear all.
I'm also interested in optimization of dynamic aperture.
I trying to run the example. But It is not operate in windows OS.[It is desktop, Win7]
This problem is samely occur in my linux PC.[It is desktop, Ubuntu9]
I get some error message, such as "couldn't execute "csub": no such file or directory."
So, I delete the "csub" in scanTune files. but still it has a error, such as "unable to open K2 in mode r: no such file or directory."
If someone know that how to fix this error, please let me know.
Sincerely yours.
Hwang, Ji-Gwang
Contact:
Post by michael_borland » 13 May 2010, 16:36
Ji-Gwang,
If you are using the files I uploaded for the tune scan and don't have the "csub" command, just edit the script to replace "exec csub elegant..." with "exec elegant..." It should work, but will be slow since there's no parallel execution of jobs.
wguo
Post by wguo » 13 May 2010, 18:14
You can also try the elegant input file attached in my previous email. It doesn't need any shell commands.
Weiming
Post Reply
