Dear Michael,
I have one question about the sc solver in Elegant.
As explained in the manual, it is the BE formula based on the Gaussian assumption; meanwhile, it is also assumed
that the beam distributions are elliptical in x-y space.
For a very strongly coupled beam near linear coupling resonance, the beam is tilted in real space (x-y).
In that case, I would say the BE formula has to be applied in the tilted frame.
Do you think it is the correct argument? And does Elegant do the frame rotation for SC kicks?
Many thanks
Chao
space charge solver
- Contact:
Re: space charge solver
Chao,
Because the space charge is applied as a kick at discrete locations, which involves integrals over the beta functions up and downstream of the kick location, it isn't straightforward to properly account for x-y tilts. At present, elegant doesn't attempt to do it.
