Dear Michel,
I am puzzeled with a somewhat basic problem. i.e. when I provide quadrupole strength error in quadrupole, it does not gives any change in beta in twiss output file, not producing any beta beat. I feel my way of input is not applying the error. please tell me where I may be doing mistake.
&error_element name=Q*, element_type=*QUAD*, item=K1, amplitude=1e-2, cutoff=3, bind=0 &end
for the lattice element defined as
Q1 : kquad, l = 0.300000, k1 = +2.3361, n_slices=15,integration_order=6
I have attached the .ele and .lte file.
With regards
Saroj Jena
problem in inserting quadrupole strength error
Saroj_Jena
- Attachments
- codhbsrs.ele
- (734 Bytes) Downloaded 595 times
- hbsrsVer2.lte
- (5.68 KiB) Downloaded 549 times
- Contact:
Re: problem in inserting quadrupole strength error
Saroj Jena,
The problem is that there is no major action command in your input file. The error_element commands are merely setup commands; they don't assign errors to the elements, but only set up the assignment.
See the attachment for a working example.
- Attachments
- codhbsrs.ele
- (797 Bytes) Downloaded 584 times
Saroj_Jena
Dear Michael,
Thanks a lot. Now I got where I was doing mistake. I tried with & bunched beam & end , & track & end . Even though it was not plotting betabeat. But it now gives betabeat because of "output_at_each_step = 1" in the twiss_output module, which I missed. Thanks once again.
With regards
Saroj Jena
With regards
Saroj Jena
