Horizontal phase space distortion with KQUAD
Post Reply
tiansk
Post by tiansk » 27 May 2017, 03:13
Hello,
I'm confused about some tracking results.We generate initial particles with gaussian distribution,ultra-low emittance 80pm,0.4% energy spread,etc...Then we let the particles pass through a simple DBA,the horizontal phase space is very odd.However,when we change the elements CSBEND to SBEND,KQUAD to QUAD,and default_order=1 in run_setup,the result seems to be better.After communicating with others,we think the element KQUAD and CSBEND may produce chromatic-like effect on the emittance. Could you explain this two different results?
Thanks!
Tian
arc_new_dba.lte
(2.22 KiB) Downloaded 587 times
beam_A.out
initial particles
(1.98 MiB) Downloaded 570 times
pass_dba.ele
(1.01 KiB) Downloaded 622 times
Contact:
Re: Horizontal phase space distortion with KQUAD
Post by michael_borland » 30 May 2017, 08:18
Tian,
The &sdds_beam command in your .ele file references beam_A.out, which you didn't provide. I used the initial particle file you provided instead.
I found several problems with the tracking setup, having to do with not specifying the "N_KICKS" parameter on the CSBEND, KQUAD, and KSEXT elements. The defaults are rarely sufficient and it up to the user to set these appropriately. For your case, I suggest 100 for CSBEND, 30 for KQUAD, and 10 for KSEXT.
The other issue is that the beamline has non-zero chromaticity, so a beam with non-zero energy spread is expected to grow in emittance. Of course, using first-order matrix based tracking will not show this.
Post Reply
