Best way to scan through/Optimize Betax & Alphax?
Post Reply
Zamank
Post by Zamank » 10 Feb 2014, 16:04
Hi All,
I was wondering if there was a better method of optimizing the beta and alpha functions. I am basically trying to perform a 2D parameter scan at the entrance of 4-Dipole Chicane and optimize the emittance (ecnx) at the exit. Currently, I am running a script that goes through all the values, but with not much precision. My script is attached.
Is there a better way of doing this?
Thanks in advance!
runscript.txt
File extension changed to allow upload
(488 Bytes) Downloaded 5438 times
Contact:
Re: Best way to scan through/Optimize Betax & Alphax?
Post by michael_borland » 10 Feb 2014, 21:27
You can optimize the results of tracking from inside of elegant. Use a TWISS element to alter the beta functions at the start of the chicane, then use "ecnx" as part of your optimization function. You didn't upload the elegant input files so it is hard to give a more detailed response.
Zamank
Post by Zamank » 11 Feb 2014, 17:20
Hi Michael,
I attached my .lte and .ele files. Tried to get it working on my own, but still need a little help so it seems...
I specifically want to minimize the ecnx at the exit of the chicane (BX24) by just varying the beta's and alpha's.
Thank you!
help.lte
(156.9 KiB) Downloaded 5458 times
help.ele
(1.51 KiB) Downloaded 5421 times
Contact:
Post by michael_borland » 12 Feb 2014, 11:32
Here's an example of how to do tracking based optimization of the twiss parameters. I didn't find much improvement, however. It seems very insensitive to these parameters.
2014-02-12.zip
(13.6 KiB) Downloaded 5559 times
Post Reply
