R Matrix For Every Element?
Post Reply
Zamank
Post by Zamank » 03 Dec 2013, 12:03
Hi All,
Sorry if this is a silly question (I just started with Elegant), but I would like to:
-Get the Rij matrix components for every element in my beamline (namely interested in R56).
I tried putting in the matrix_output option in my .ele file but no 's%.mat' file is written and I get the error:
"warning: 577 elements had no matrix"
Any help would be greatly appreciated. I can provide the .lte/.sdds files needed to run my .ele file (but I'm pretty sure my issue is with my command).
help.ele
(1.8 KiB) Downloaded 520 times
Contact:
Re: R Matrix For Every Element?
Post by michael_borland » 03 Dec 2013, 12:37
Please post the .lte file. Don't see any obvious problem with the .ele file.
Zamank
Post by Zamank » 03 Dec 2013, 12:49
Here is the lattice file; I have the other .sdds files, but they are over the 2MB size restriction. If needed I can probably send them to you some other way!
Thanks again in advance!
help.lte
(173.81 KiB) Downloaded 489 times
Contact:
Post by michael_borland » 03 Dec 2013, 13:00
I removed all the references to other files and made some small changes to the .ele file. It works as expected, see attached.
You can do
Code: Select all
% elegant help.ele
% sddsplot -column=s,R56 help.mat
help.lte
(156.59 KiB) Downloaded 547 times
help.ele
(1.51 KiB) Downloaded 532 times
Zamank
Post by Zamank » 03 Dec 2013, 13:41
Yup, that fixed it...so simple too :?
Thanks a bunch Michael!
Post Reply
