Hi Michael and collaborators,
is there a way to plot x-x' at each pass of a ring (Poincare` plot) indicating the point with the Pass number rather than a symbol or dot ?
Best regards, Max
Labelling turn numbers in Poicare plots
- Contact:
Re: Labelling turn numbers in Poicare plots
Max,
Alas, no. You can color-code the particles with the pass number, as follows
% sddslot -column=x,xp data.sdds -split=page -graph=dot,vary -order=spectral
