alter_elements
Post Reply
broemmel
alter_elements
Post by broemmel » 07 Oct 2012, 10:41
In the .ele file
&alter_elements
name = X107
item = FILENAME
string_value = booger
&end
gives the output
&alter_elements
name = X107,
item = FILENAME,
type = {NULL},
exclude = {NULL},
value = 0.000000000000000e+00,
string_value = booger,
differential = 0,
multiplicative = 0,
verbose = 0,
allow_missing_elements = 0,
allow_missing_parameters = 0,
start_occurence = 0,
end_occurence = 0,
s_start = -1.000000000000000e+00,
s_end = -1.000000000000000e+00,
after = {NULL},
before = {NULL},
&end
In save_lattice output there is only
X107: WATCH
which of course generates the following error
MPI_File_open failed: MPI_File_open failed: File does not exist, error stack:
(unknown)(): File does not exist
ADIOI_UFS_OPEN(67): File does not exist
Contact:
Re: alter_elements
Post by michael_borland » 10 Oct 2012, 08:09
I tried this and it worked fine with both elegant and Pelegant. Can you post a complete set of files that exhibit the problem?
Post Reply
