how can I use this grammar ?
Joytop
Re: how can I use this grammar ?
Post by Joytop » 17 May 2012, 06:55
Dear Michael,
That's much close.
Now I caculate the s1(=Sx),s2(=Sxp) and s12 by ex and twiss parameter .
I get ex from .sig :
s1 s2 s12 ex ElementName
m m m
2.841564e-04 2.955620e-04 8.242936e-08 1.609421e-08 W11
I get twiss from .twi :
betax alphax ElementName
m
1.870317e+00 -1.261194e-01 W11 then gammax= (1 + alphax^2)/betax= 0.5432;
Then I can get: s1 = sqrt(betax*ex)=sqrt (1.870317e+00 * 1.609421e-08 ) = 1.7350e-004
s2 = sqrt( gammax*ex)=9.3501e-005
s12 = -alphax * ex = 2.0298e-009
but the results I get are different from the s1,s2 and s12 from .sig. Why ?
Joy
Contact:
Post by michael_borland » 18 May 2012, 10:08
Joy,
Is it possible that the beta functions used for the beam (loaded via sdds_beam) are not the same as those given to the &twiss_output command?
You can use sddsanalyzebeam to check the beta functions etc of the beam file.
Joytop
Post by Joytop » 18 May 2012, 20:58
Hi, Michael :
I have already used the right beta functions from sdds_beam to the twiss_output command. They were consistent. Do you think there are some wrong in my .ele file I posted it several days ago ?
Best,
Joy
Contact:
Post by michael_borland » 18 May 2012, 21:43
Joy,
I don't see an obvious problem with the .ele file. Does the beam have large energy spread?
Assuming you are using QUAD and DRIFT elements, you can try setting default_order=1. This will turn off any aberrations and you should get better agreement.
Joytop
Post by Joytop » 18 May 2012, 21:52
Michael,
I have set default_order=1. I can not see Sdelta0, rms energy spread, in .twi file. And sddsrugert can only analyze the energy spread of undulator. I have not found anyelse can do with enery spread in the manual.
Best,
Joy
Contact:
Post by michael_borland » 18 May 2012, 22:13
Joy,
sddsanalyzebeam will analyze the energy spread of a beam file. Also, the &run_setup sigma=<filename> feature will show you the energy spread, plus the beta functions computed from the beam. You can compare these to the results of &twiss_output and see where the discrepancy starts.
Joytop
Post by Joytop » 18 May 2012, 23:51
Michael,
The Sdelta(energy spread) is 1.349871e-03 after the Astra(the begining of Elegant) from both .sig file and sddsanalyzebeam file , and Sdelta at the reconstruction point is 8.107814e-03 from .sig file. Is it too big ? Is it the factor of the dsicrepancy I mentioned above? Does it influence my constructions ?
Also I have comparad the beta functions in .twi file and the results of beta functions calculated from s1 and ex in .sig file . They are the same at the begining, but the discreapancy starts from the next element(the accelerating tube A1P)
Fox instance, I calculate the betax using s1 and ex from .sig at the element DBLL2:
betax_calculated = s1^2 /ex = 3.769923e-04 * 3.769923e-04 / 1.875018e-08 = 7.5798 , but the betax in .twi at the element DBLL2 is 7.5847.
alaphax_calculated = -s12 /ex = -2.710423e-08 /1.875018e-08 = 1.4455, but the alphax in .twi at the element DBLL2 is -1.44402.
Yes the discrepancy the this element near the begnning is samll , but it is large at the end (about 1-2) .
Best,
Joy
Joytop
Post by Joytop » 19 May 2012, 00:28
Dear Michael,
I have a new question :
I want to calculate the emittance and s1 ect from the color density plot x-xp as the attchment. Yes, it's really that the dot plot over state the wings. I finished the color density by sddshist2d and sddscontour. Can you give me an example to calculate the emittance ect from the data produced by sddshist2d.
Best regards!
Joy
Joytop
Post by Joytop » 23 May 2012, 02:43
Dear Michael,
I calculated the s3,s4 and emittance in Matlab use the color density image data produced by sddshist2d(sddshist2d inputfile outputfile -col=y,yp -xparam=400,-0.001,0.001 -yparam=400,-0.001,0.001). Then the outputfile data is the density matrix and can be used to calculate ey. The results are different from the s3,s4 and ey from .sig file . And the error is high to 30% !
I can show you the results :
s3 s34 ey s4
W10 4.116129e-04 9.927426e-08 1.276723e-08 2.431699e-04 (from .sig file, tracking result)
W10 2.7187e-004 4.1770e-008 8.0477e-009 1.5647e-004 (from sddshist2d results)
W10 3.9145e-004 4.4390e-008 1.6001e-008 1.2054e-004 (from my reconstructed image data)
Joytop
Post by Joytop » 23 May 2012, 05:27
Post Reply
