oagtclsh. Where to get it?
Moderators: cyao, soliday
Post Reply
dpe
Post by dpe » 22 Mar 2012, 10:04
I had a fresh install of elegant compiling from the source yesterday. Now I'm running some examples and studying the manual to get familiar with it.
A very interesting tool I would like to use is view3dGeometry. The script has been correctly installed with elegant, but when I run it, it complies that oagtclsh is not present. I have not found any kind of documentation explaining where to get it and how to install.. Can you please tell me something about?
Thank you
Contact:
Re: oagtclsh. Where to get it?
Post by michael_borland » 29 Mar 2012, 11:06
You can get this from the software download page at
http://www.aps.anl.gov/Accelerator_Syst ... ware.shtml
Look for "Tcl/Tk"
dpe
Post by dpe » 29 Apr 2012, 05:42
I have been looking around for much time, but I've not been able to figure out how to compile this from the source. I can't find any reference to this in the Linux Installation guide. Any help would be much appreciated.
Thank you!
soliday
Post by soliday » 30 Apr 2012, 10:40
It is very complicated to compile from source code. The preferred method is to install the linux RPM. If you are on a 64 bit linux computer try installing:
http://www.aps.anl.gov/asd/oag/cgi-bin/ ... x86_64.rpm
If you are on a 32bit computer you can use:
http://www.aps.anl.gov/asd/oag/cgi-bin/ ... 6.i386.rpm
If either of these won't don't work on your version of Linux, then let me know what version you are using any I will try to compile a version of oagtclsh for you.
dpe
Post by dpe » 30 Apr 2012, 11:15
Thank you soliday, I'm running a 64bits ArchLinux. I think that somehow this (fantastic) distribution can also install RPM. I will try to follow this way.
Best regards
Post Reply
