Hi Michael,
Is it possible to set an energy distribution which is different from particle distribution in ELEGANT?
In &bunched_beam you can just set particle distribution and ELEGANT takes the same distribution for the energy.
Thanks,
Farzad
Energy distribution
- Contact:
Re: Energy distribution
Farzad,
I'm not sure what it would mean to set an energy distribution independently of the particle distribution. What are you trying to compute?
Dear Micheal,
My question is a general question. For example, How can I get a bunch with linear particle distribution in X but a Gaussian energy distribution also in X?
(or any other distribution which is different from the particle distribution)
Farzad
Farzad
- Contact:
Farzad,
By "Gaussian energy distribution also in X", you mean that there is dispersion? If so, then just specify values for eta_x and sigma_dp . For example
Code: Select all
&bunched_beam
! x betatron distribution
distribution_type[0] = "line",
beta_x = 1
emit_x = 1e-9
! energy distribution
distribution_type[2] = "gaussian",
sigma_dp = 1e-3
! x distribution involves energy via the dispersion
eta_x = 0.1
&end
