Is it possible in Elegant to get "flux density curve" and "radiation spectrum" by tracking a beam in a field map?
I am going to track 10000 particles and then use the distribution file ( .out) at the end of the beam line to calculate the spectrum in a magnetic field map.
Farzad
Radiation calculation from a field map
Re: Radiation calculation from a field map
Farzad,
That feature is not available in elegant. You may want to look at the SPECTRA code from SPRING8.
