Hi!
So, I'd like to vary some quad positions on an overall fixed distance, i.e. vary the drift lengths between them while keeping the sum of the lengths constant. How would I implement this in elegant?
Best regards
Jonas
Optimizing with "coupled" variables
Re: Optimizing with "coupled" variables
Jonas,
You can use the optimization_covariable command for this purpose. E.g., suppose your beamline is
and you want to move Q1 around while keeping the total length constant. You can use
"D1.L0" and "D2.L0" stand for the original values of the lengths, whereas "D1.L" is the trial value.
D1: drift,l=1
Q1: quad,l=0.5
D2: drift,l=1
bl: line=(D1,Q1,D2)
&optimization_variable name=D1, item=L, lower_limit=0, upper_limit=2, step_size=1e-3 &end
&optimization_covariable name=D2, item=L, equation="D1.L0 D2.L0 + D1.L -" &end
Hi!
So, I finally got around to trying this a little while ago. I have a case with more magnets and drifts (4 and 5, respectively), so I implemented the final drift as a co-variable similarly to what's described below. The problem is that I couldn't find a way to prevent this drift from getting negative values, the code just output a warning. How would I go about solving this?
Best regards
Jonas
Best regards
Jonas
Jonas,
You can add an optimization term using the length of D2. E.g.,
This will rise rapidly from 0 when D2.L is less than 0.
&optimization_term term = "D2.L 0 1e-6 selt" &end
I tried implementing it this way, but I get the error
Do you know what causes this?
Best regards
Jonas
error: too few values on stack (popn)
Problem evaluating expression: I.BC1_DMID3.L 0 1e-6 selt
RPN expression errors prevent optimizationBest regards
Jonas
Jonas,
It appears that I.BC1_DMID3.L does not exist. Compare with the attached example.
- 2018-06-26.zip
- (842 Bytes) Downloaded 646 times
