Minimizing maximum beam size in a lattice
Post Reply
libov
Post by libov » 28 Nov 2013, 08:34
Michael,
I'd like to optimize the lattice in such a way that the maximum beam size along the whole lattice is not exceeding a certain value.
Just minimising beta function won't work (I'm dealing with beams having large energy spread) so I really need access to beam size from tracking.
Is there a built-in possibility to do this? I mean, something similar to what one can do with the beta function (i.e. max.betax will find a maximum of betax in the whole lattice)
One less convenient option I see is to use several MARK element along the lattice and to use Sx or Sy at each occurence in optimization_term.
Before doing that I thought it's a good idea to ask you whether there is an easier way.
Thanks in advance for your time!
Slava
Contact:
Re: Minimizing maximum beam size in a lattice
Post by michael_borland » 30 Nov 2013, 11:57
Slava,
Unfortunately, there are no statistics for beam sizes, so using MARK elements is the only possibility for now. There are some things you can do to make this easy:
Use &insert_elements to add many markers with the same name:
Code: Select all
&insert_elements
        name = *
        element_def = "M1: MARK,FITPOINT=1"
&end
This will insert a marker named "M1" after every element.
Then, use the following command to add the optimization terms
Code: Select all
&optimization_term
  term = "M1#@.Sx sqr",
  field_string = @,
  field_initial_value = 1, field_final_value = 1000, field_interval = 1
&end
This will create optimization terms for Sx^2 at 1000 M1 elements, starting from occurrence 1.
Post Reply
