Simplex Algorithm
Posted: 26 Aug 2013, 09:09
Dear all,
The simplex optimization method is recommended in the elegant manual. I used it for the optimization of an extraction arc and it worked fine. However, I was wondering if you could tell my why the simplex method is recommended and not any other optimization algorithm. Is it the fact that this method does not require the derivatives of the optimization function which makes it faster and more stable?
Thank you in advance!
Best regards,
Matthias
Best regards,
Matthias
