Solution with mirror symmetry
mcarla
Post by mcarla » 04 May 2020, 08:53
Dear elegant community,
The matched option in the twiss_output command allows to find solutions with periodic condition:
Beta_initial = Beta_final
Alpha_initial = Alpha_final
Is there a way to find solutions with mirror symmetry?
Where with mirror symmetry I mean that the initial and final betas are the same, while initial and final alphas have same value but opposite sign:
Alpha_initial = -Alpha_final
Thanks in advance.
Michele
Re: Solution with mirror symmetry
Post by michael_borland » 05 May 2020, 18:25
Michele,
That's not a feature in elegant presently. I usually just find the solution for the system (Cell,-Cell) in a case like that.
I'll look into adding it.
mcarla
Post by mcarla » 06 May 2020, 06:39
Thanks a lot for the reply. Solving the system (Cell,-Cell) is fine if you are looking for symmetric solutions with Alpha_initial=Alpha_final=0 but in this case I need only Alpha_initial = -Alpha_final.
If you can implement it would be great, otherwise I can give it a try.
Thanks again,
Michele
Post by michael_borland » 06 May 2020, 08:40
Michele,
Sorry, I didn't fully understand what you wanted. I think the best way to find such a solution is using the optimizer. You can insert a TWISS element to allow varying the initial parameters and then set up optimization terms to get the matching you need.
Out of curiousity, what's the application?
mcarla
Post by mcarla » 06 May 2020, 10:36
I'm designing a cell made of a central FODO section enclosed by two matching sections.
The strategy I'm following is to design the FODO first and only after add the matching sections.
I don't really need the FODO to have periodic solutions, I just need the solutions to be symmetric,
in fact I can always tune my matching section for whatever Alpha I need at the entrance and exit of the FODO section.
Michele
