When the flag is set (output_at_each_step = 1), the following optimization_covariable throws an unknown token:
&optimization_covariable
name=TB, item=betax, equation="MW#1.betax"
When I comment out the output_at_each_step flag, the previous optimization_covariable works just fine, but the following optimization_term does not (another unknown token error):
&optimization_term
term = "SW.ANGLE atan 0.25 0.01 selt"
Since I can get one or the other to work depending on how the output_at_each_step flag is set, I know that everything is defined properly enough. Is this the intended functionality of output_at_each_step? If so, I do not understand it.
Edit: EDRIFT items don't appear to cause any problems, but KQUAD elements fail similarly to the CSBEND elements.
Edit: A set of files that can be used to recreate this problem are located in this topic:
viewtopic.php?f=9&t=1104
