Optimization of lattice with MATTER element
Post Reply
pratik
Post by pratik » 07 Nov 2024, 19:46
Hi,
I am looking into using the MATTER element with thicknesses less than 0.001
X0. Is there a way to use this element and optimize the lattice?
The probabilistic model does not allow me to easily do this. However, if I can stop it from changing after some evaluations, it could be possible.
Let me know if this could be possible.
elegant.lte
(867 Bytes) Downloaded 3197 times
elegant.ele
(1.5 KiB) Downloaded 3361 times
Best,
Pratik
Contact:
Re: Optimization of lattice with MATTER element
Post by michael_borland » 12 Nov 2024, 17:13
Pratik,
You can try using the &transmute_elements command to turn the MATTER elements into drifts.
Code: Select all
&transmute_elements
        name = *, type = MATTER, new_type = DRIF
&end
&run_setup
pratik
Post by pratik » 25 Jan 2025, 19:51
Hi Michael,
Thanks for your reply. I do want the MATTER element to be there. Do you think setting restart_random_numbers = 0, is a better choice. I do get the optimization to work with that change but it is still not monotonically decreasing. I am also switching to parallel_optimization for faster convergence. Let me know what you think about this and if there is any better way to do it. I am attaching the files.
pratik
Post by pratik » 11 Feb 2025, 20:12
pratik wrote:
25 Jan 2025, 19:51
Hi Michael,
elegant.lte
(874 Bytes) Downloaded 2582 times
elegant.ele
(1.85 KiB) Downloaded 2648 times
Contact:
Post by michael_borland » 24 Feb 2025, 16:34
If you want to optimize with the MATTER element in place, then setting restart_random_numbers=1 in the optimization_setup command is the right thing to do. That should ensure that the random effects are the same each time.
Post Reply
