Suggestion to linearize the z-delta phase space?
Post Reply
Zamank
Post by Zamank » 12 Sep 2017, 17:43
HI All,
If I wanted to linearize the longitudinal phase space of a linac+linearizer system for a given linac phase (which should remain constant during optimization) does anyone have a suggestion on the best way to go about this?
Currently, I am using elegant's simplex optimizer/minimizer with the optimization term "s56 1e6 *" while varying the XBAND (phase, voltage). I attached a sample *.ele file.
But I am wondering if theres a better way to do this?
Thanks in advance!
sample.ele
(553 Bytes) Downloaded 626 times
Contact:
Re: Suggestion to linearize the z-delta phase space?
Post by michael_borland » 13 Sep 2017, 10:39
Linearizing the phase space should correspond to the minimum longitudinal emittance, so I'd try minimizing "el".
Post Reply
