error on optimization
Hi all, I am probably doing something silly but I can't find a solution to this. I have initially found a similar post by user Marcello named, "Strange Dispersion Calculation" where the problem was the inability at writing a final output file after the optimization. This is well explained in the reply, where the "optimize" command is a "major action", wiping out the problem space.
In my case, however, I am trying to run an optimization with no further action.
Specifically I 'd like to find the gradients of some skew quads to give a certain coupling. When running I can see the optimization does the job,
but the last line shows some problem occurred (in red)
Dumping final properties data...done.
Optimization results:
optimization function has value 5.55359509000862e-09
Terms of equation:
emittanceRatio 0.003 - sqr: 5.553595090008622e-09
A total of 38 function evaluations were made.
Optimum values of variables and changes from initial values:
QSKEW.1B.K1: 2.356250000000001e-01 2.356250000000001e-01
QSKEW.1C.K1: -1.231562500000000e-01 -1.231562500000000e-01
QSKEW.1D.K1: -5.196875000000000e-02 -5.196875000000000e-02
QSKEW.2A.K1: 2.623437500000000e-02 2.623437500000000e-02
statistics: ET: 00:00:04 CP: 3.55 BIO:0 DIO:0 PF:0 MEM:22602
error: run_setup, run_control, and beam definition must precede track namelist
I am quite puzzled since run_setup, run_control and bunched_beam all precede the track command as recommended
Below the .ele file used.
Thanks very much for any help
Marco
Terms of equation:
Marco
- Contact:
Re: error on optimization
Marco,
The reason is that &track and &optimize are both major action commands. After your optimization finishes, you need to save the the results (e.g., using &save_lattice or using a parameter file in &run_setup). Then you start over with a new &run_setup command and invoke the just-saved lattice (or load the parameter file). You can then define a beam etc. and finally issue &track.
Thanks very much for the prompt reply!
Indeed this sorted out the problem
Continuing on the same line I have another question then.
I want to optimize now against the ratio e2/e1 from the calculation of beam_moments, so I introduce
a block like:
&moments_output
filename = %s.mom,
matched = 1,
equilibrium = 1,
radiation = 1,
output_at_each_step=1,
&end
however I am not sure how to use this information. With output_at_each_step=1 the output file .mom is empty. With output_at_each_step=0 the *.mom file is non-empty. In both cases parameters e1 and e2 are not present when doing the rpn evaluation causing an error:
unknown token: e2
unknown token: e1
too few items on stack (divide)
*stop*
too few items on stack (subtract)
*stop*
Problem evaluating expression: e2 e1 / 0.003 - sqr
RPN expression errors prevent optimization
I attach the tentative .ele file for reference
a block like:
&moments_output
filename = %s.mom,
matched = 1,
equilibrium = 1,
radiation = 1,
&end
unknown token: e2
unknown token: e1
*stop*
*stop*
- Contact:
Marco,
Unfortunately, the e1, e2, and e3 parameters aren't provided for optimization in the present release. I'll add that in the next release.
Meanwhile, you can access the elements of the sigma matrix at the location of a marker. First, define a marker, e.g.,
and put it in your beamline.
Then, use optimization terms like
I know this isnt' quite the same as optimizing e2/e1, but it should be quite close.
Code: Select all
M1: mark,fitpoint=1
Code: Select all
&optimization_term
term = "
M1#1.s33 M1#1.s44 * M1#1.s34 sqr - sqrt
M1#1.s11 M1#1.s22 * M1#1.s12 sqr - sqrt
/ 0.003 - sqr"
&end
thanks Michael
I have followed your advice, put the marker, and tried to evaluate the s11,s12 etc. terms at that point.
However MRK#1.s11 is not found, while for example MRK#1.s12 is. I have seen that moments_output saves
s1 rather than s11, so I have tried to see if I can access that term unsuccessfully.
In general I am not sure which variables I can use to define an optimization term. Is there a general rule?
Thanks
Marco
here the .ele + .lte file used for this case
Thanks
Marco
- Attachments
- ORC_dlsi0913_corrlen.new
- (22 KiB) Downloaded 784 times
- CPL_moments.ele
- (3.17 KiB) Downloaded 794 times
- Contact:
Marco,
Sorry, my previous message contained an error. The symbols to use are "s11m", "s22m", "s12m", etc. The extra "m" is to distinguish the &moments_output calculation results from the similar results from tracking.
You can find a more-or-less complete list of what's available for optimization by looking at the discussion of the "equation" parameter of the &optimization_setup command and also by looking at the documentation for the MARK element.
Attached is an example of a simulation that runs based on your files. I had to allow stronger skew quads to get convergence. I also adjusted the &optimization_setup command and made one change in the lattice file.
- Attachments
- 2015-06-01.zip
- (324.57 KiB) Downloaded 782 times
Thanks a lot Michael! it was really useful and it' s running now
My final goal is computing the lifetime in a machine where I have introduced several effects (misalignment errors, gradient errors etc), corrected the orbit, tune, chromaticity, introduced a defined coupling (which is the reason of this post actually). I call this a "realistic lattice".
To compute the momentum aperture I load the "realistic lattice" as described above and also introduce all the previous parameters. I have notice however that -at least when running in parallel mode- I get an error
Error: unknown parameter XREFERENCE used for BB CSBEND (parse_element)
and realized that XREFERENCE is not present, nor other parameters like F1,..F8.
In practice when loading the file with the parameters I should exclude these specifications, XREFERENCE, F1, F2, ... F8:
BB XREFERENCE 0.000000e+00 CSBEND 48
BB F1 0.000000e+00 CSBEND 48
BB F2 0.000000e+00 CSBEND 48
BB F3 0.000000e+00 CSBEND 48
BB F4 0.000000e+00 CSBEND 48
BB F5 0.000000e+00 CSBEND 48
BB F6 0.000000e+00 CSBEND 48
BB F7 0.000000e+00 CSBEND 48
BB F8 0.000000e+00 CSBEND 48
When using load_parameters option exclude_item_pattern, it works with a single name but seems to fail (for me at least) when I try to put together two or more different names.
So for example:
exclude_item_pattern = "XREFERENCE" excludes XREFRENCE
exclude_item_pattern = "F?" should exclude F1, ...F8
but how do I exclude all of them? "XREFERENCE F?" does not work
thanks Marco
So for example:
thanks Marco
- Contact:
Marco,
It appears that you are running a quite old version of Pelegant, which explains why those parameters are missing from the internal element definitions. It probably also explains why the exclude_item_pattern option doesn't work as expected (the ability to exclude multiple patterns was added in the last few releases). You should upgrade.
Barring that, you can use sddsprocess to remove the unwanted data from the parameter file:
Code: Select all
sddsprocess CPL_dlsi0913_corrlen.param CPL_dlsi0913_corrlen.paramFiltered \
'-match=column,ElementParameter=XREFERENCE,ElementParameter=F?,|,!'
