Dear elegant users and experts,
I have a further question concerning my elegant optimizations. In a conference proceeding from ICAP2000 (in Darmstadt/Germany) from Michal there was introduced a "save_parameters command which writes an SDDS file that can be used with load_parameters to restore the configuration of the lattice at the time the save was made".
My tests to use this command like the save_lattice command (which works fine) at the end of an optimization failed and my question was if I did something wrong or if the save_parameters command is not implement any more or if it was probably replaced by a new command. The command is not listed in the online manual.
Thanks again in advance for your help!
Best regards,
Matthias
save_parameters command in elegant
- Contact:
Re: save_parameters command in elegant
Matthias,
Sorry for the confusion. There isn't a separate save_parameters command. Instead, one gives a value for the parameters field of the &run_setup command. This will result in saving the parameters to the named file at the end of optimization.
Hi Michael,
thanks again for the quick response and for your help!
Best regards,
Matthias
Best regards,
Matthias
