Fitting Beam Size Measurements
Post Reply
tennant
Post by tennant » 17 Sep 2010, 11:40
Hi,
We have (rms) beam size measurements at various points along a transport channel. I'd like to use Elegant to vary the Twiss parameters at the entrance of the the transport channel to minimize the difference between observed and simulated beam sizes. I suppose I could create an optimization_term for each beam size measurement but that would become unwieldy to manually enter each new set of measurements. I've got to believe there is a faster way to do this...
Thanks,
chris
tennant
Re: Fitting Beam Size Measurements
Post by tennant » 20 Sep 2010, 11:42
So I grossly overestimated my ability to do what I described in my previous post and now have more fundamental questions. I want to vary the Twiss parameters and emittance at the start of a transport channel to minimize the difference between measured and simulated beam sizes at various locations. Presumably I use the 'Twiss' element to generate the optimization_variables for the beta and alpha in each plane. How do I vary the emittance? And how do I generate an optimization_term for the measured beam size? At the moment I have 'Watch' elements at all viewer locations in the lattice. Can I do something like: term = "Viewer01.SX(Y) 0.5e-3 - sqr"?
Thanks.
chris
Contact:
Post by michael_borland » 27 Sep 2010, 11:01
Chris,
Please see the attached file for an example of how to do this.
beamSizeMatch1.tar.gz
(1.37 KiB) Downloaded 1362 times
tennant
Post by tennant » 27 Sep 2010, 13:11
Michael,
Thanks for the example. I (think) I understand what you are doing, however when I apply it to my file I run into problems. After the optimizer runs, it has not changed any of the twiss parameters or emittances and the value of the fit function is ridiculously high. I don't understand it. I'm attaching the .ele and .lte if you'd like to have a look. I'm not expecting a super fit of the data, but I'm certainly something better than I'm currently getting!
Thanks,
chris
cdt.lte
(1.44 KiB) Downloaded 1467 times
cdt.ele
(3.18 KiB) Downloaded 1469 times
Contact:
Post by michael_borland » 27 Sep 2010, 13:45
Chris,
I think the basic problem is that your MARK elements have names that begin with a digit. This is ok until you use them in RPN expressions. RPN doesn't properly recognize variable names beginning a sequence that looks like a number. So 8F03.SX gets interpreted as "8".
Another problem is that you refer to markers (e.g., 8F12) that don't exist. Finally, you use ".SX" and ".SY" instead of ".Sx" and ".Sy".
tennant
Post by tennant » 28 Sep 2010, 08:25
Ah, yes. Thank you. I also forgot to put the occurrence in (i.e. TV8F06#1.Sx).
tennant
Post by tennant » 28 Sep 2010, 13:28
One more question, I've seen how you can change the Twiss parameters and emittance with the 'twiss' and 'emittance' elements, respectively. Is there a straightforward way to vary the initial longitudinal parameters (i.e. bunch length and energy spread) for fitting purposes?
Contact:
Post by michael_borland » 28 Sep 2010, 13:31
Chris,
You can use a MAGNIFY element to do this in a relative fashion (i.e., using factors relative to the initial bunch length or energy spread).
I should really add longitudinal emittance and beta function transformation in the same fashion as for transverse...
jtobin
Post by jtobin » 11 Mar 2013, 17:04
Hi Michael,
Is there now an element to vary the initial bunch length? Will be an useful one. Thanks!
-Charles
Contact:
Post by michael_borland » 11 Mar 2013, 17:07
jtobin wrote:Hi Michael,
-Charles
Charles,
You should be able to do this with the MAGNIFY element, e.g.,
Code: Select all
MAGS: magnify,ms=2
should multiply the bunch length by a factor of 2. May not work well if the beam has a significant velocity spread.
Post Reply
