Error in calculating dynamic aperture in presence of
Post Reply
ranamonikaa
Post by ranamonikaa » 28 Jul 2025, 10:18
Hi,
I am attempting to calculate the dynamic aperture with an initial momentum offset applied to the beam. However, regardless of how small the momentum spread is, I consistently encounter the following error:
Unable to update page--new number of rows less than previous number (SDDS_UpdateBinaryPage)
Problem setting SDDS parameter values (do_aperture_search)
This issue arises when I include the following line in the input:
&vary_element name=MALIN, item=DP, initial=-0.0025, final=0.0025, index_number=0, index_limit=11 &end
If I remove this line, the dynamic aperture calculations run successfully without any errors.
I'm unable to determine what is causing this behavior. I’ve attached the relevant .ele and .lte files for reference. Any help in resolving this would be greatly appreciated.
Thank You!
A3.lte
(6.13 KiB) Downloaded 4761 times
DA__momoffset.ele
(4.31 KiB) Downloaded 5134 times
Contact:
Re: Error in calculating dynamic aperture in presence of
Post by michael_borland » 14 Aug 2025, 16:18
I downloaded your files and they work without errors. Perhaps try the latest version of the code?
ranamonikaa
Post by ranamonikaa » 13 Oct 2025, 23:38
I have tried this with the latest version and still getting the same errors. is there anything else that I should do?
-Monika
Contact:
Post by michael_borland » 27 Oct 2025, 17:54
Monika,
I was able to reproduce this error. I'm not sure why I didn't see it before.
The problem is that you have a WATCH element in the beamline while doing a DA search. This causes some confusion in the code about the length of the table necessary to store the data. I'll see what I can do to fix the problem.
Meanwhile, a workaround is just to remove that WATCH element.
ranamonikaa
Post by ranamonikaa » 13 Nov 2025, 06:14
Thank you for the clarification. But Interestingly, the same setup works fine for the APS example lattice file, so I wasn’t expecting it to cause an issue in my case too.
Post Reply
