Thank you for your efforts. I tried installing using the Elegant x64.msi file and when running elegant it says its version 34.0.0 not anything labeled 34.0.1, is this still the correct version? The website says that it was edited today so it should be the right file.
Thanks,
Ryan
SIGSEGVProgram Crash with FTABLE Element
Re: SIGSEGVProgram Crash with FTABLE Element
Sorry about that. I somehow copied the old version over instead of the new version for the Windows downloads. Try it again.
No problem, thank you for your help
Many thanks, everything works in my case as well!
