Hi Michael,
Today I noticed an issue with the alter_element when applied to the RFCA element. I have attached a simplified example that reproduces my observation. To reproduce my problem I have prepared two .ele file one as the alter_element command that set the voltage to what it is in the .lte file while the other does not have the alter_element command.
The sequence is as follows:
run elegant test_noalter.ele
sddsanalyzebeam cryomodule_end.out -pipe=out | sddsprintout -pipe=in -col=pAverage
gives 2.801039e+02
run elegant test.ele
gives 1.780903e+03
I have double check and think my rpn expressions are all OK. Thank you for any help.
-- Philippe.
problem with alter_element applied on RFCA element
- Location: Northern Illinois University & Argonne National Laboratory
- Contact:
- Attachments
- test.tar
- tar file to reproduce problem
- (1.39 MiB) Downloaded 395 times
- Contact:
Re: problem with alter_element applied on RFCA element
Philippe,
I found two problems with your input files
- When giving an rpn expression for a value in the .ele file, the expression must be enclosed in parentheses, e.g.,
This tells the parser to treat the string as an rpn expression, rather than a literal string.
Code: Select all
&alter_elements name = CAVE item = VOLT value = "(12.0305E+06 0.11797 * 0.9665 *)" &end
- Some of the expressions in test.ele have the value 0.11797 for the length, while those in test.lte have 0.11543. I think the latter is correct.
- Contact:
Michael,
Thank you very much. Sorry I should have thought about the parenthesis... -- Philippe.
