MATLAB sddsload not working with error log file
Posted: 08 Feb 2016, 10:03
Hello everyone,
I am using the sddsload function for MatLab and it works perfectly for all the sdds files produced by elegant but not with the ".erl" files produced with &error_control error_log=%s.erl &end.
When I issue the command
I get the following error
Error using sddsload (line 30)
invalid parameter value at line #82 (readAsciiData)
It appears not to be able to parse the "ParameterError" column: I say this as I did
And then everything works fine.
I am using MATLAB 2015 and SDDSver 2.8
Is this a bug or I am doing something wrong?
Thanks in advance for your support,
Giovanna
Code: Select all
val=sddsload('test.erl')Error using sddsload (line 30)
Code: Select all
sddsconvert test.erl -delete=col,ParameterError
val=sddsload('test.erl')I am using MATLAB 2015 and SDDSver 2.8
Giovanna
